FB Twitter Instagram
ORION Delta™ Desktop 3D Printer RTP™
  • Sale
  • Regular price $1,049.00
  • SKU: 87999
The Orion is discontinued
GET STARTED - FAST - WITH YOUR OWN DESKTOP 3D PRINTER FROM SEEMECNC.  WITH MORE STANDARD FEATURES, MULTI-MATERIAL CAPABILITY, STANDALONE PRINTING AND INCLUDED SD CARD READER AND LCD CONTROL PANEL.
  •  Up-front LCD panel to show the status of your print
  • On-board SD card (included) for storing up to 4GB of print files (that's an average of apx. 2700 prints!!!)
  • Heated build surface
  • High speed positioning (up to 300mm/s)
  • 6" diameter by over 9" tall cylindrical build volume (apx. 175 cubic inches) or 5" Square by 9" tall box shaped build volume
  • Comes standard with a .5mm nozzle
HOW WELL DESIGNED IS OUR ORION DELTA?
We designed the Orion Delta and Rostock MAX machines to print with ABS, as well as PLA and many other materials too!  You don't need to buy special edition machines, or add aftermarket gadgets and gizmos - they just work with the materials from the start.  Since we tackle one of the more difficult materials in our design first, the rest are easy.
The Orion Delta™ 3D Printer comes set up and calibrated from our factory, which is right here in northern Indiana.  Each and every machine is built by enthusiastic 3D printer gurus from the ground up.  Your machine will come ready to run right out of the box, with just minimal adjustment and setup (due to packaging and shipping).  From the moment you open the box, you'll be ready to print, FAST!
 Orion Delta Specifications
Overall Printer Size
14" Diameter
Overall Printer Height 24" tall
Overall Printer Weight 18 Pounds
Power Requirements 100-240 AC 350 Watts (Selectable on power supply input)
Shipping Dimensions 30" X 16" X 16" Box weighing 27 pounds
 Build Area
Maximum Printable X/Y Area 6" Diameter (150mm)
Maximum Printable Square Size 4 1/8"" (106mm)
Maximum Printable Z Height 9 1/4" (235mm)
 Printing Specifications
Avg. Print Speed 30-100mm/s
Max Movement Speed 300mm/s
Max Hotend Temperature 280c
Max Heated Bed Temperature
120c
Part Cooling Fan
Included (G Code Controlled)
