FB Twitter Instagram
SeeMeFPV 2204-2300kv MultiRotor Motor
  • Sale
  • Regular price $12.00
  • SKU: 26821
These 2204 - 2300kv motors are great performance motors for any multirotor build and especially FPV racers.  They come with a 5mm right hand threaded bolt on style prop adapter that's replaceable so if you ever strip out the threads you don't have to throw the whole motor away, simply replace the adapter.  We have both right and left hand adapters available as well if you need to replace them.
Specs -
  • 200mm motor wire leads
  • M3 motor mount holes - 16mm x 19mm pattern
  • M2 prop adapter mounting holes - 9mm 4 hole pattern
  • Comes with M2 x 5mm and M3 x 5mm hardware
  • Includes 3 2mm bullet connectors
  • Includes standard right hand 5mm prop adapter
Here's the links to the replacement prop adapters -
Right Hand
Left Hand
