This is a genuine brand Mean-Well 12 volt DC power supply is rated at 350 watts and features a selector switch for 110/220VAC 60Hz.
Specification
- model LRS -350- 12
- no mounting hardware included
- qty 1
Compatibility
- BOSSdelta 300
- BOSSdelta 500
- Artemis 300
- RostockMAX v4
- RostockMAX v3.2
- RostockMAX v3
- Orion - late model only
Caution:
Improper use of this product may cause injury, fire, or product damage not covered by warranty. We do not have any recommendations for applications other than use in SeeMeCNC 3D printers designed. Use at your own risk.
There are 4 mounting screw holes in the bottom as well as 4 mounting screw holes on the sides allowing the power supply to be securely mounted using M4 x 0.7 screws. It is your responsibility to ensure screws do not enter into the power supply frame more than 4mm.
