Compatibility with SE300 v1.3 PCB's (older design 2016-2018)
- Artemis 300
- RostockMAX v3.2
We recommend updating to the new PCB and whip update kit
Installing a replacement hotend power connector on a stock SeeMeCNC printer:
1) power off machine
2) note black and red wire positions, then cut off existing connector
3) strip just less than 1/4" (6mm) of each wire
- pull wire strippers straight
- DO NOT twist strands of wire
4) insert tiny flat screwdriver into rectangular slot of pluggable connector to release the gripping mechanism
5) pushing straight, push in the correct color wire into corresponding hole until the insulation of the wire recesses into the pluggable connector. No bare wires or stray strands should be protruding. Repeat for both wires.
6) check for short circuit, then plug into the hotend
