FB Twitter Instagram
Hotend Accelerometer Probe PCB Board Rev 6a
  • Sale
  • Regular price $37.00
  • SKU: 71210
Our accelerometer PCB board is available here for those who want to experiment with their own setups using the on board I2C accelerometer circuit.  It has our standard 8 pin pluggable connector, hotend cold section and fan and part cooling fan connections as well as a place to wire in an LED for print lighting under the platform.  You will need to purchase one of the 8 pin pluggable connectors to plug your wiring into this PCB board.  PCB ONLY - No other parts/hardware are included with this item
Other Details
  • 5VDC
  • Center Hole 7.4mm Diameter
Compatibility
  • RAMBo controller printers
  • Rostock MAX v3
  • Rostock MAX v2
  • Orion
  • H2
  • Eris
  • HE280 series Hotends
This product is not compatible with the newer 32bit Duet controller boards.
 Source Files Available Here:
https://github.com/seemecnc/Machine_Elements/tree/master/71210%20HE280PCB%20Files
