CLOSE OUT NO WARRANTY NO REFUND IMPORTS
WE DO NOT NEED THESE ANYMORE. They do not meed our quality standards, however you can benefit. Use them in your projects!
Close out pricing
These are 16 tooth G series timing belt idlers. They have a 2mm pitch and fit timing belt 6mm wide. They are used with our G series timing belts. Compatible with GT2-2 belts.
Compatibility
- These are no longer used on SeeMeCNC printers.
- search 32556 (click here) for Artemis Idler Replacements
Includes
- 1 pc 16T aluminum idler pulley
Specifications
- flange outside diameter = 13mm
- overall width = 8.5mm
- 3mm ID ball bearings
- 2mm pitch for 6mm wide belt
- aluminum
