Updated 2023: This kit now includes a genuine MeanWell 12V PSU.
CLICK below for replacement PSU without the kit:
Power Supply 12 VDC 350W MeanWell – SeeMeCNC
These Power Supplies are included in RostockMAX v2 & v3 kits. They are similar to the common upgrades many users have replaced their ATX style with. This kit comes with everything you need to upgrade to this style power supply including the wiring, connectors, cooling fan for the base enclosure and more.
IF UPGRADING FROM A PREVIOUS MODEL:
For installation into a RostockMax v2, you will prepare the power supply based on the instructions here on pages 33-37: PSU Installation
For mounting the power supply, you will need to either drill four 5mm holes in the base of your machine using this PDF template or you can install the power supply with 2 sided tape / velcro (preferred method).
Specs:
- 12v adjustable output
- 29 amp max. output
- 115/230 AC input selectable
Includes the following:
- IEC connector mount
- 110v AC power cord
- Rocker Switch
- 5 - 18g Spade connectors
- 2 - 12g ring terminals
- 5 - 18g ring terminals
- 4 - M4 x 16mm Phillips mounting screws
- 4 - M4 Washers
- 2 - 6-32 x 1" Phillips Screws
- 4 - 6-32 x 1 3/4" Phillips Screws
- 6 - 6-32 Nylon Lock Nuts
- 1 - 60mm Cooling Fan
- 12" 18g red wire
- 23" 18g black wire
- 14" 12g red wire
- 14" 12g black wire
- 8" 18g green wire
- 8" 18g white wire
- AC Power Warning Label
- 4 - Lasercut Standoffs (not always necessary for mounting)
- 1 - Lasercut Right power input panel
